slave cylinder upgrade!!!!
Old Dec 16, 2003 | 03:11 AM
bjt1998's Avatar
Does anyone know were I can get a slave cylinder upgrade kit for a 99 SS?:
Old Dec 16, 2003 | 03:15 PM
SSpdDmon's Avatar
Check the sponsors of this website. They should have the redesigned slave in the transmission sections of their websites. If you can't find it there, I'd call Jason Cromer (www.samtaylor.com) down in FL. He got me mine for a fair price shipped to my door in a weeks time. Good luck with removing the tranny.
Old Dec 16, 2003 | 04:08 PM
BigZ28's Avatar
We've got the 01+ slave cylinder if your still looking.
Texas Speed
Thanks!
Brian
Old Dec 17, 2003 | 12:58 AM
bjt1998's Avatar
So I have to pull the transmission out to put the slave cylinder on?
I thought it was on the outside of the transmission.
Old Dec 17, 2003 | 01:34 AM
SSpdDmon's Avatar
On older f-bodies, I believe it was on the outside and the setup used a "fork" to engage/disengage the clutch. But on ours, the slave cylinder slides over the input shaft of the tranny and directly engages/disengages the clutch. After recently attempting my own clutch swap (and failing miserably ), I found the original pos slave quite worn and swapped it for a new one. Word of advice...lifts and tranny jacks work wonders.
Old Dec 17, 2003 | 01:48 AM
bjt1998's Avatar
Well while I have the transmission out I will put in a new clutch to.What kind would you put in your SS? Do you know were I can get everything I need? slave cyl,master cyl, clutch, I want something that will last. The Best!!!
Thanks for your help.
realistyc
Jul 28, 2015 07:32 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
NewsBot
Jul 8, 2015 06:47 PM
robyyzpapa
Jul 7, 2015 10:05 AM
