Size of Pacesetter Lt's
Old Sep 23, 2003 | 12:12 PM
myricekiller's Avatar
Anyone know how big the Pacesetter Lt's are? texas speed doesn't say n i need to know so i can buy cats to put in a y pipe tyi
Old Sep 23, 2003 | 10:58 PM
chpmnsws6's Avatar
its a 3 inch Y-pipe and there would be no way you could fit cats under the car....... its already tapping my floorboard when i take off
Old Sep 23, 2003 | 11:49 PM
i was just going to put the heat shield from the cat on the y pipe not the cat but i see what your seeing. So there is really no way to run a catted y pipe with pacesetter headers? Anyone from Jersey have long tubes do you have off road pipes with no cat or a y pipe with the shell of a cat? So lt's n orp it is. It's that tight of a fight where its bumping the floorboard?
Old Sep 24, 2003 | 12:09 AM
Aklaim's Avatar
Dont buy the Y pipe they sell......get a custom one made....then you can have your cats.
Old Sep 24, 2003 | 07:51 AM
My84Z's Avatar
the pacesetter y pipe fits like *** get either a custom one or i believe jet hot makes one with cats that fit.
Old Sep 24, 2003 | 09:02 AM
would i hooker y pipe work with the pacesetter lt's? if so i'm thinkin bout buyin it then throwin the cat in. I know that its different for every shop but what kind of base price do you think i'm lookin at for fabbing up a orp with the heat shield from a cat?
Old Sep 24, 2003 | 07:41 PM
chpmnsws6's Avatar
pacesetter is a knock off of hooker so it should work
i needed ground clearance so the tight fit is no problem for me
93 RedBird
Nov 15, 2015 08:24 AM
colts0455
Sep 11, 2015 06:16 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
RobFlag
Aug 29, 2015 11:40 PM
