should I buy this 115k miles ls1 yes on no?? (right now have lt1)
should I buy this 115k miles ls1 (right now I have 340rwhp lt1)
Right now I have 95 LT1 Trans am (with 89k miles). I am thinking about purchasing 1998 Trans am (6 speed), the only thing is that ls1 has 115k miles. It doesn’t burn any oil, or any other problems. How bad is buying high mileage ls1?? Any things I should look for??? How good are the ls1 engines?? I know that lt1 are stronger, a can go for more miles without rebuild. How about ls1??
ps. I can have it for $6k
Re: should I buy this 115k miles ls1 yes on no?? (right now have lt1)
First of all, LT1s are not necessarily stronger than LS1s.The LT1 comes with a 2 bolt main and the LS1 comes with a 6 bolt main. While the LS1 is inherently weak due to it being totally aluminum, the 6 bolts mains make it just as strong if not stronger than the LT1 on the bottom end. Also, stock LS1 heads flow better than ported/polished LT1 heads and that's where a lot of the HP gain comes from. In short, there are no serious problems common to the LS1 regardless of miles, while the LT1 has a very weak link with the opti spark. I would not hesitate to buy a LS1 with 115k miles on it. However, if your TA is paid for then a head/cam may work better for you. Either way, they are killer cars and good luck.
As long as it has been taken care of and not been beat on all the time, I wouldn't really have to think too long if I could get it for 6K.
LS1's are at least as strong as the LT1's. As long as you keep up with the maintenance, either one will go well beyond 200K.
Just give the car a thorough inspection and go from there. Good luck!
TS
TS
Look at the articles in Car craft and hot rod.....A school picked one up with over 100K and now it runs 11.5's with no issues, aside from the fact that the knock sensors went bad...wow, really hard fix. I wouldn't waste too much time thinking if I had the $6K to spend. If you could why not keep the LT to race and the LS for the daily...That's what I would do, or maybe do it the other way around.
Chris
Chris
Thanks for all replays. I have dilemma: keep my Lt1 or purchase this 115k ls1. What I don’t like about my LT1 is its roughness, all the rattles, and it is too loud. Besides that it drives perfect!! Ls1 in other hand looks better (ws6 hood , and respond better to mods...
What are main issues with high mileage ls1???
My ls1 has 91k on it and it doesn't seem to have any problems, it burns a little oil but i haven't seen a chevy motor that hasn't done that. I will not part ways with my lt1 though. If you can, buy the ls1 and keep the lt1 and make it a race car. The only thing that bothers me about my ls1 is the piston slap when i first start the car on a cold morrning, it goes away once its warmed up though.
I believe theres a problem common with the LS1 PCVs...but I don't have any problems with mine yet and I have 230K miles on it.
The LS1 aluminum block doesnt have any problems supporting BIG hp....If I was you I would just put a heads and cam on the LT1if its paid off, thats because I would never buy any performance car w/ that many miles unless I had a rebuild plans in the near future....a lloyld elliot H/C LT1 set up is very reasonable and will give you around 400 rwhp
The LS1 bottom ends are in fact stronger than the LT1's. As many 400rwhp h/c stock bottom end LT1's there are, there are about as many 500rwhp h/c LS1's out there on stock bottom ends. I'd say the blocks are similar in strength though. LS1's are getting cheaper to mod by the day it seems, so I'd probably spend the money building the LS1 if you buy it and keep the LT1 as a daily driver. But you really can't go wrong with either motor honestly.
Jason
Jason
I purchased my 99 SS a year ago with 115k on the clock. The car was in excellent condition with only a few minor flaws. Mechanically it is sound and the car was extermely well maintained...especially considering that it's black. I took it to the track and though it ran 14.4s initially, eventually ran 13.2s with nothing more than driving improvements.
