SES light code P0420
Camaro book says this is "cat converter left bank". SES went off after awhile but now is back on. What could this be? A muffler shop checked it and said the cats were fine. Has been no noticeable performance hit. Any suggestions greatly appreciated.
2002 Z28
85mm MAF
K&N Filter
SLP Loud Mouth
RAM cut out
2002 Z28
85mm MAF
K&N Filter
SLP Loud Mouth
RAM cut out
Re: SES light code P0420
It's most likely a bad driver's side cat - covered under the federal emissions warranty for 8yrs/80K. Do a search here for "P0420" it's a very common problem. Welcome to the board.
Did they replace it? My buddy had his replaced w/GMMG and cutout installed. If not try another dealer - even a catback shouldn't be a problem, Corsa catbacks are "GM approved."
I've had that code pop up twice with my car now (~44,000 miles on the clock). Funny enough, I had a catalytic go bad about a month ago (I honestly don't even know which side?!
) but the code came in about a month or two before getting the new cat, and now a month later!
Originally Posted by hoss932004
Man the dealer gave me a rash of crap! They didn't want to warranty it because I had modified the exhaust. But I only put on Loud Mouth tail pipes.
Better not add anything else like pinstripes or that dealer won't touch your car anymore.
Well they finally gave in after 2 hrs of debating. They said they would go ahead and replace both of the cats but only because they were "bolted in." Had the tubes been welded...no way they would do it. Guy at muffler shop advised me to get some kind of bolt in pipes to get rid of the cats and bolt the cats back in come inspection time. Any tips on this?
Get them changed first and then if u want, go for the offroad pipes but not sure if u'll have the problem of rasp since u have the SLP LM even though u don't have LT's....not sure. That is BS kinda though, SLP should be approved and not void the warranty since they work with chevy/GM. I had a rattle by the gas tank heat shields a couple weeks after i installed my GMMG. When i took it to the dealership the guy asked me what was wrong, i told him i think it's the gas tank heat shield. So i started it up and he made a joke about not fixing it under warranty but he didn't care. Surely enough it was my GMMG rubbing on a heat shield and they fixed it for me at no charge. Another time before that i kinda f'ed up my car and my passenger side cat started to oxidize and after a month my ses light went on cuz it made a hole in the cat. I took it to the dealership thinkin i would have to pay for it to fix it since i'm sure they could tell i hit something, but they fixed it free of charge.
Gtpguy
Jan 26, 2015 04:50 PM
Jul 4, 2005 05:00 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Z28Wilson
Aug 1, 2002 04:27 PM
