Service Engine Soon
Old Jun 7, 2004 | 03:36 PM
CableWS6's Avatar
Service Engine Soon
Hey guys once again i was just driving down a road at 30mph and check engine soon light came on. i had this happen 8 monthes ago and i ended up needing to catalytic converter. Could it be bc my cutout has been open for a couple monthes. Should i take it somewhere first to find out problem. then take it to dealership bc i have 100$ deductable. Wut would be my best option... Maybe new O2 sensors should i try to get gutted cats or a whole new catback???
Old Jun 7, 2004 | 06:57 PM
Greed4Speed's Avatar
Tighten your gas cap and reset the comp and see if it pops on again.
Old Jun 7, 2004 | 07:01 PM
CableWS6's Avatar
how do u reset comp
Old Jun 8, 2004 | 03:55 AM
AL SS590 M6's Avatar
Moderator
Originally posted by CableWS6
how do u reset comp
Turn key on but do not start
under hood pull PCM bat and PCM ign fuses
wait ~10 minutes
turn off key
re-install fuses
Old Jun 8, 2004 | 08:39 PM
`99 Super Sport's Avatar
Get the code pulled at a place like Autozone, etc. See what the problem is first. If its major, or you can't figure it out, go to the dealer for warranty. If its simple you can fix it and KNOW what it was instead of pretending it didn't happen and hoping it'll go away.
Old Jun 8, 2004 | 08:57 PM
AronZ28's Avatar
Autozone has a scanner tool that will read your trouble codes for free, and I believe they can also clear the memory and old codes for free too.
Old Jun 9, 2004 | 07:50 AM
bond449798's Avatar
Re: Service Engine Soon
same thing happened to me my ses light came on and i went to the dealer and they changed 1 of my cats then a week later it came back on so i go back to the dealer again and they had to change the other cat. light has not come back on since.
Old Jun 9, 2004 | 09:33 AM
shortdog273's Avatar
Yes, autozone can scan AND clear your code(s) for you at no charge.
Old Jun 11, 2004 | 06:24 PM
WHT98SS's Avatar
Its your cutout, it happened to me with my 01. the chevy guys said the computers were more sensitive on the newer f bodys, it never happened to me with my 98. i reset my computer and it stayed off but came on every once in a while.
Old Jun 12, 2004 | 02:11 AM
Schantin's Avatar
I guess it depends on the Autozone. The one I went to in Austin REFUSED to clear my code for "liability" reasons. They will read it for free though.
BTW, is your cutout located before or after your rear O2 sims? If it's before, I could definetly see that bringing on the SES light.
Schantin
2002 Camaro Z28 M6
Old Jun 12, 2004 | 05:23 PM
CableWS6's Avatar
I dont even know. It was on there when i got the car. Just got m car back though said it was teh 02 sensors. Anyway im thinking about just getting catback i got enough money so im jsut trying to find the best deal to install them and which set up i want.
Old Jun 12, 2004 | 10:46 PM
watsonusa's Avatar
That would explain allot, because after I installed a flowmaster and HPPIII, I started throwing SES codes for the cats as well. The dealer replaced one of the cats and all was well for a while then more codes. So, I replaced the flowmaster (the 2000 rpm drone killed me) with a Dynomax, and dropped the HPPIII engine tuning.
Since then I've seen the code twice in a year...Not twice a month.
cheapchevy
Apr 8, 2015 08:48 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
Injuneer
Dec 15, 2014 09:36 AM
mspennyhughes
Nov 28, 2014 03:22 PM
transamtom
Aug 4, 2002 01:35 AM
