Safe Rev Limit ?
Old Oct 19, 2004 | 09:45 PM
JoeMack's Avatar
Safe Rev Limit ?
What would be a safe rev limit to set on an LS1 with stock valvetrain?
Old Oct 19, 2004 | 10:13 PM
Capn Pete's Avatar
Re: Safe Rev Limit ?
I'd go up to 6500 maybe, but with a standard I'd be careful you don't really over do it, 'cause you will risk bending pushrods (seems to be the most common problem ). Upgrade your valvetrain and rev the sucker over 7000 rpm if you wanted to though!!
Old Oct 19, 2004 | 11:50 PM
94ZRiCeKiLr's Avatar
i've heard the stock valvetrain will live at 6500 but honestly i wouldn't push the limit past 6300 (stock rev limit is 6250 i believe.) i remember a couple of magazines awhile back testing GM LS1 crate engines and getting valve float right around 6K....seems a little weird, but that's what they found.
Old Oct 20, 2004 | 03:50 AM
AL SS590 M6's Avatar
Moderator
Factory.
When you up grade the valve train then futz with the rev limiter.
G-BODYT56
Jan 14, 2022 11:14 PM
KYWes
Sep 26, 2015 08:49 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
rideordie
Sep 7, 2015 08:22 AM
