is this safe????
is this safe????
I was playing with my hypertech today and i upped my shift points 2 mph for 1-2 and 2-3. i made a quick pass (only first and second gear) with the car hooked up to an autotap and it registered a MAX 1st gear RPM of 6212 RPMs. My valve train is stock and the car feels great with the shift up higher......is this TOO high????
rev limiter is set to 6400 rpm. sound ok??
i dont bother trying to shift it....i was great at it with the stock converter but its real tough to get right with this one. i just leave it in drive....i'd like to get a shiftlite but i wouldnt know where to set it since theres that delay between the time u actually shift the shifter and the time the transmission switches gears.
thanx for the input...
Originally posted by rwb
No, you can safely go to about 6400 rpms. Understand that your tach is going to always be slow so you will need a shift lite or just leave it in drive.
If you look around at the LS1 specific sites you will see that most people do run them to 6400 rpm's.
Most people bend pushrods due to miss shifts at high rpms.
You have an A4. You are much LESS likely to bend a pushrod than if you had an M6
. I also had my rev limiter set to 6400 or 6500 when I went to the track this summer so I could experiment with raising shift points to see if / how much it helped
. No problems that I know of so far
. I think it's only risky if you've got an M6, where you are likely to miss a shift and rev beyond ~6400 rpm.
thanx for the input everyone...i've always heard it was usually M6s that bend pushrods but i just wanted to make sure everything was cool....
think u can --> 2 tenths would put me a lot closer to bolt on only 11.99
but im not that optimistic about getting that much...
(not running ridiculous pig-rich and not having a FULL weight car would help too lol)
once again thanx for the input!
but im not that optimistic about getting that much...(not running ridiculous pig-rich and not having a FULL weight car would help too lol)
Originally posted by robb4964
My rev limiter on my LT1 was raised to 6300 and i ran it there more times then i can count . W/all the miles on it it never done a thing to it
. The stock LS1 pushrods have been known to bend every now and then when over-revved
Originally posted by Capn Pete
Yeah, but there is one big difference between the LT1 and the LS1 which makes it unsafe to rev the LS1 too high on stock internals --- PUSHRODS
Aug 7, 2015 08:52 AM
Jul 10, 2015 02:23 PM
Jan 23, 2015 01:13 PM
