Running too cold?
Old Dec 8, 2010 | 03:25 PM
The Intern's Avatar
Running too cold?
The warmest the thermostat in my car ever indicates is about ~170 degrees.
It usually sits right there, around the 160 degree mark and I can hear the fans kick in to cool it every time it hits 170. This doesn't really bother me much in the summer, but now that its cold I think its affecting the heater. I already flushed the heater core, which helped a little, but its still not 100%.
I know that these cars are supposed to operate at around 185 or 190, right? But if its just the thermostat, why would the fans be kicking in?
Old Dec 9, 2010 | 07:18 AM
Chevyssoccer's Avatar
Re: Running too cold?
what year is your car? It sounds like the guage is just wrong.
Old Dec 9, 2010 | 08:31 AM
Bayer-Z28's Avatar
210* is the text-book operating temperature. (stock T-Stat opens at ~180*) The 98 F-Cars are the only ones that have an actual 'functioning' temp gauge. Do you have a 160* stat installed and tuned for it? If so, this could be why. Combined with cold winter ambient temps.
Old Dec 9, 2010 | 09:07 AM
The Intern's Avatar
Its a 98 and it had the stock thermostat in it. I replaced the thermostat with a stock replacement and it still indicates the same temperature. I've never had it tuned to run at 160.
Old Dec 9, 2010 | 05:03 PM
Bayer-Z28's Avatar
^ Only other way to tell is to shoot the top of the Stat housing with an IR Thermometer to give you an idea of what the temp might me.
Old Dec 12, 2010 | 01:58 PM
BandDirector Blk98ZM6's Avatar
That's where mine runs all the time with my 180 degree Thermostat. I had a 160 a LONG time ago and it wouldn't get off the 160 degree mark on the guage. It really looks like you've got an aftermarket Thermostat installed, or it's stuck open.
Old Dec 17, 2010 | 12:24 AM
bill2129's Avatar
mine runs cool to just a little below the first line. thats just because of my ss hood gets air in it when i drive. if you wanna know if it works or not let it idle for 15mins and see if it goes up
Jan 23, 2015 01:13 PM
Britbilly
Jan 7, 2015 08:49 PM
cmdeshon
Dec 27, 2014 10:06 AM
jayblev95
Dec 1, 2014 06:55 AM
nophix
Nov 30, 2014 10:26 PM
