rockers
Old Feb 11, 2004 | 06:44 PM
imyeepeepaw's Avatar
rockers
has anyone put a set of stud mount rockers on a ls1 yet i have been thinking about the comp 1.75 but i wont to keep the pedastal mount they are so much easier to setup
Old Feb 11, 2004 | 06:48 PM
teke184's Avatar
did a lot of research on those couple weeks ago.
the problem is that the stock springs are all but maxed out on lift...so even going from 1.7 to 1.75 you'd need to change springs
which makes the task alot more involved.
and if you plan to do a cam later (or have one now) EVERYONE reccomends against changing rockers...something about the ramps too steep on the cams to work properly
Old Feb 12, 2004 | 11:22 PM
thanks for the advice i already have a cam and springs now i just want a better rocker i hate the factory rockers they make too much noise
Old Feb 13, 2004 | 06:22 AM
teke184's Avatar
yella terra 1.7 ratio would be a good choice for an aftermarket cam
there is an install guide on either www.ls1howto.com or www.ls1camaro.net
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
