rev limiter
rev limiter
Well when I was coming home from work, i wanted to try shifting the auto manually, so i put it in first. when i floored, i forgot to shift it into second. i know i'm stupid, i was pretty damn tired. i stalled for four seconds before shifting into second. my question is if i damaged the engine by my stupidity? thanks for the help.
Did you hit the Rev Limit where the car just kind felt like it was sputtering ?? Well from what I have read about these cars (2002) w/ the 4L60E is they have a Rev Limiter built into the transmission and the computer will kick it in to keep from damaging the engine.. I did this on my car when I testdrove it with the salesman in the car and at first I thought I messed the car up but it did not.. I hit 60 mph in 1 st gear when it kicked in about 6,000 rpms and when I actually shifted it, nothing was wrong..
I would not worry about it unless there is an odd noise...
The transmission does not have a rev limiter..cmon now.. and to do 60 mph in an A4 ls1 with the factory 6200 limit you would need a 2.50 gear ratio to hit 60mph at 6000.. with a 2.73 you would be at 6600rpm at 60mph, and with a 3.23 you would be a 7800rpm at 60mph..
Your rev limiter is 6200 thru the computer.. its possible you could have hurt something.. maybe floated a valve and hit a piston with a valve and bent some pushrods..
you wont know now unless you check..
dont take this the wrong way.. your a dumbass
dont forget to shift
Originally posted by stik6shift98
ya i dont like when my buddies put their autos in first and they drive it like a stik car......the transmission can hold its own and yes it can shift faster then u can
.Also, unless you held the car on the rev limiter for a long time, it's not going to hurt the engine...............don't do it all the time, but don't worry that after the first time you've hurt the engine - unless you hear something definitely f'd up
.BTW: it is possible to hit speeds close to 60 mph. My car can easily hit 90 km/h, which is 55 mph in 1st, and if you hold right until the limiter, it'll do ~95 km/h, or about ~58 mph
. Again, not something to make a habit of though
Sep 11, 2015 09:44 AM
