Rearwheel or crank
Old Jun 14, 2002 | 01:33 AM
2002Z28's Avatar
Post Rearwheel or crank
Do our Z28's have 305ish rwhp or 305 hp at teh crank?
Old Jun 14, 2002 | 07:10 AM
CPFarhood's Avatar
Post
The ls1 cars range from about 285-290RWHP to as high as 320rwhp, the 305 i guess is just some number thrown out there by GM why they chose 305 i couldn't tell ya.
Chris
'98 Black Z28 M6
Lid, EGR Mod, Borla Exhaust
SLP Short Throw & ****
http://cpfarhood.tripod.com
AIM: CPFarhood
*Boycot Roseville*
Old Jun 14, 2002 | 07:50 AM
HawkCMC's Avatar
Post
When car manufacteurers rate their cars horsepower its at the crank. GM just way underrated these cars.
CMC
1999 Firehawk
*SLP Lid, Holley Filter
*Thunder 224 112 lsa Cam
*Hooker LT Jet Hot Headers, Custom Y Pipe.
*BMR STB,LCA,SFC,LCA Brackets,Panhard Rod
Old Jun 14, 2002 | 01:20 PM
Camaro ChriSS's Avatar
Post
As stated above, the 305 hp GM uses is horsepower measured at the crank. Virtually no manufacturers state hp ratings at the rear wheels. It's nice though that most LS1s when actually tested rate closer to 305 hp at the rear wheels (and not just the crank), implying 350 hp at the crank, unofficially.
2000 Pewter SS #C161
SLP Dual-Dual, Bilstein suspension, Eibachs, 21mm/35mm swaybars, GMAF
SLP CAI w/lower plate, !EGR, Direct-Flo, SLP STB, Ported TB, ASP Crank pulley
SLP/AAM Differential cover, SLP 2600, Powershot, MSD wires, NGK's,
BMR Boxed LCAs, BMR PHB, G2 DSL, Heavy Lead Foot...
http://community.webshots.com/user/murlynd
Old Jun 14, 2002 | 02:24 PM
mmannSS's Avatar
Post
just a little more info: they are rated at 310 by GM (at the crank) and the SS is rated at 325 by GM (at the crank). Now in reality they are putting down around 300 to 305 (no matter if its a Z28 or SS). The 98 99 2000 models were a little lower because the 2001 and 2002's got a different cam. Basically the range is from about 285/290 to about 305/310 at the rear wheels (with some freak cars getting like 315 to 320) the lower end usually being the pre-2001's. you can see what my 2002 got with about 5,000 miles on it.
2002 Camaro SS #2288 M6
!CAGS
Stock Dyno Run with 5,460 miles:
RWHP 302.7
RWTQ 320.5
Jeff1904
Jun 5, 2016 05:00 PM
68camaroboltz
Oct 5, 2015 11:56 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
95craz28
11
Sep 12, 2015 07:47 AM
Aaront810
Sep 11, 2015 11:24 AM
