Rear end problem possibly? HELP!!!
Old May 16, 2003 | 12:11 PM
JDohn2001's Avatar
I think my rear might be going. When I start to accelerate from a stop, my car makes a thump/grind sound from the rear and it feels like a skip in acceleration and it only lasts for less than a second. I tried accelerating from a stop but this time I pushed it a little harder and the sound got a little louder and more of a grinding sound and it lasted longer. It will also do it if I floor it from a 30-40 mph roll. Can someone tell me what might be wrong. BTW my car is a 98 SS with torsen rear, A4 with 3500 stall converter and 36000 miles, also my rear wheels are 17x11 with BFgoodrich drag radials.
Old May 16, 2003 | 02:12 PM
asianice25's Avatar
id say its probably starting to go. Turn off everything and roll the windows up on a quiet street. when you slow down for a stop sign listen for a "knocking" sound coming from the rear end. Thats a sure sign of the 10 bolt dyin...
Old May 17, 2003 | 10:27 AM
norcalstreet's Avatar
A rearend typically will not making a grinding noise like your describe. It will whine but I won't rule out the rearend entirely. Check the rearend for leaks. The cover gasket and pinion seal being main culprits.
I would inspect the driveshaft and torque arm. A bad joint on a driveshaft may make this sound or a cracked torque arm.
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
ModdedNerd
Dec 25, 2014 05:51 PM
FredM
Dec 18, 2014 01:40 PM
