Rear End Oil
Rear End Oil
I had to do some rear end work a week or so ago, and I had to replace the rear end gear oil/lube. At the time, all that was available to me was Quaker State 80W-90 GL-5 Synthetic for Limited Slip Rear Ends. I went to the dearlership today and they wanted $27 per quart of the GM stuff that the manual recomends. Mobile 1 was only $7 per quart. Do I really have to put the GM oil in there, and does anybody know why GM oil is so expensive?
I am no expert on this but I think you can use any gear lube you want as long as it meets the viscosity and weight ratings the manual calls for. I do believe that gm has an additive you have to put into the fluid because of the limited slip diff. May want to check with the service department for a definate answer.
Re: Rear End Oil
