random misfire
Old Oct 1, 2006 | 06:06 PM
BlackBADaSS02's Avatar
Question random misfire
I just changed my plugs and wires the other day. Autolite Iridiums and MSD wires. I have HP Tuners, so I was using it to look for misfires. My SES light does not flash, and no codes show up, but HP Tuners is telling me that cylinders 2,4,6,7,8 are misfiring 0-4 times per cycle. It happens more at idle than when cruizing. Any idea on what could be the cause, or should I just not worry about it.
Old Oct 1, 2006 | 09:14 PM
AL SS590 M6's Avatar
Moderator
Re: random misfire
If it doesn't set your SES don't worry.
Old Oct 1, 2006 | 09:58 PM
Bayer-Z28's Avatar
Re: random misfire
an 02, huh?... I'm thinking cam sensor signal is falling off.. I believe that's what tells the computer to fire which cyl... but if it's from a newly changed part, it most likley wouldn't be that..
I haven't heard of LS1's running Autolites... those are typically Ford Plugs. I had a wicked bad misfire problem on my previous car due to Bosch Platnums. ...Bosch no workey on GM DIST less ignition.
Old Oct 3, 2006 | 10:18 AM
skifast87's Avatar
Re: random misfire
do you flat out feel and difference or hear any thing. If you got miss from my experence your gonna know about it. It might sound like a pop or kind of like a back fire if its bad.
Old Oct 3, 2006 | 12:43 PM
teke184's Avatar
Re: random misfire
are you sure the plugs are gapped correctly?
how bout the wires pressed all the way on the coil or the plug??
93 RedBird
Nov 15, 2015 08:24 AM
greenzee28
Sep 25, 2015 04:29 PM
Aaront810
Sep 11, 2015 11:24 AM
damnyankee36
Sep 9, 2015 07:06 PM
tdigger9899
Sep 7, 2015 10:56 AM
