questions about installing my B&M trans cooler
Old Mar 23, 2005 | 12:50 AM
zo6vette's Avatar
today i got my B&M trans cooler and i have a few questions before installing it. First which trans line on the radiator is the oil out of trans? ( top or bottom?) and for the second trans line which one is the oil return to trans? (top or bottom?) iam looking at the trans cooler theres two top ports left and right, which is which? both are not labeled and i don't know what is what. where exactly do i install the cooler lines? do i splice in into the existing lines to the radiator? does anyone have any pics or diagrams to install a trans cooler? also where is a good location to mount the trans cooler? in front of the radiator? any other places that would be a good place to mount the cooler?
Old Mar 23, 2005 | 01:08 AM
Boost It!'s Avatar
Re: questions about installing my B&M trans cooler
almost ALWAYS the trans line OUT of the cooler (back to heat source) is lower.
fluid should do this:
Trans---> stock cooler ----> aux cooler ----> Trans.
You want to use as little hose as humanly possible and as few bends as you can. this usually means mounting "sideways" so you pump into the aux TOC from the side
=========----------- <-------IN
=========---------- <--------OUT
Old Mar 23, 2005 | 02:33 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
=========---------- -------->OUT
corrected your "out" arrow for you...
far as the lines where they attach to the tranny... i believe the top one goes into the tranny and the bottom one is out...
not POSITIVE tho
Old Mar 24, 2005 | 01:01 AM
whataretheodds's Avatar
|_____|
_____
_____
I also have one i wanna put on my car, Just making sure, so then the trans cooler is facing me up ward. So the left port is in and the right port is out?
Old Apr 11, 2005 | 01:17 AM
zo6vette's Avatar
I was looking at one guys formula with the trans cooler and he just had the bottom trans line spliced in and connected on the radiator and I looked at the top trans line on the radiator and it wasn't touched, so then you just splice into just the bottom trans line on the radiator and leave the top one alone?
Also I am alittle confused of which lines do I connect to on my trans cooler left and right. Which hose do I connect to the transcooler when the cooler is facing towards me? Does it matter on the cooler from In and out? So when I connect and splice one of the cooler lines to the bottom of the radiator Where do I connect it to the cooler? Left or right port? Which goes where?
Old Apr 11, 2005 | 07:49 AM
SSpdDmon's Avatar
I just did this with the help of a friend a week ago. The instructions tell you which line is the feed and which is the return coming out of the tranny. If you follow them through the k-member and around the front of the motor, you can see which ones go where. When we did it, it looked like the feed went in the bottom of the car's radiator and the return came out of the top. I tripple checked it because that didn't make much sense to me, but I was pretty sure I had it right so I went ahead with the install. We mounted the cooler with the fittings on top (because that's the only way it would fit with the super sucker), unbolted the top line out of the radiator, and connected the coolers fittings to the unbolted line and the radiator using the fittings, hoses, and clamps provided with the kit. Re-attached the super sucker, lid, bellow and sensors and we were good to go. 500 miles later no leaks and no problems. It's fairly easy...just take your time and double check your work.
94Z28LS1toLT1
Parts Wanted
Jan 21, 2015 04:37 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
hotrodyou1
Dec 20, 2014 10:05 PM
thenewkid
Nov 27, 2014 09:41 AM
lbrowne
Nov 13, 2011 04:25 PM
