Pulleys?
Old Apr 4, 2004 | 12:14 AM
LetMeBurnU's Avatar
Pulleys?
Im thinking about getting pulleys, is it worth it? what gains can u get from it?
Old Apr 4, 2004 | 01:08 AM
ULTIMTEORANGESS's Avatar
go with ASP.you can expect about a 5-8 rwhp gain.
SLP just came out with a pulley too.it seems to be descent also.
Old Apr 4, 2004 | 11:29 AM
edg1957's Avatar
I noticed good gains from my ASP, easy install. I did both pulleys too. No charging issues with the alt under drive either...
Old Apr 4, 2004 | 01:31 PM
ChrisUlrich's Avatar
What are pullies? Whats alt underdrive? SOrry for the stupid questions... gotta learn somehow... hrm
Old Apr 4, 2004 | 02:02 PM
Super Slow '97's Avatar
the pulley on the crank is smaller and the alternator pulley is larger. With the smaller crank pulley it causes all of your accessories to slow down to a more efficient level giving you more HP. Hope this helps... this is a basic explanation someone please elaborate on this some more.
Old Apr 4, 2004 | 05:58 PM
edg1957's Avatar
There are two brands of pulleys for the LS1, SLP and ASP. They function about the same...ASP sells three sets. Set one is a 25% underdrive pulley only, kit two is a 25% underdrive pulley with a 15% overdrive alt pulley. This kit puts the alternator pulley RPM back at about stock, and it is designed for cars with aftermarket stereos and other accessories that draw a lot of power. Kit three was my choice, and it has a 25% underdrive pulley with a 15% under drive alt pulley. It offers the most horsepower gain, but drops you volt meter to just above the hash marks at idle, but it charges right back up when you move. I ran mine with everything I could turn on at idle for 30 mins with no problems. All kits use a different size belt than stock, which is included, as is a new bolt for the lower pulley. Installation is a piece of cake with an impact wrench. It would be near impossible by hand unless you are a gorilla, the torque spec is 240 ft lbs!
Hope this helps!
Ed
Old Apr 4, 2004 | 09:43 PM
1stls1's Avatar
So on a A4,if you a conv and 3.73 gears and pullies,you would be up the RPM range in a real hurry?
Old Apr 4, 2004 | 10:28 PM
LetMeBurnU's Avatar
Hope this helps!
Ed
Does this mean i cant go wrong with either kits...?
it wont hurt it if i put on any aftermarket accessories later on?
Old Apr 5, 2004 | 03:45 PM
edg1957's Avatar
As long as you are not going to run big stereos and neon, I'd get the alt under drive pulley They will only enhance any power adding mods you can do.
They cost a little more, but I am all about maximizing horse power with my car!
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:37 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Slayer
Aug 17, 2015 03:55 PM
