Pro 5.0 or B&M Ripper??
Old Apr 22, 2003 | 09:08 AM
  #16
LurkerLS1's Avatar
Originally posted by demonspeed
Those are adjustable stops so you don't destroy your gears/synchro's... though I don't know if the T56 has internal stops. My Tremec 3550 has internal stops, and my shifter has adjustable stops, but they kept backing out, so I finally took the stops out and it seems to go into gear a lot better... so I don't know.
Yes, the T56 has internal stops. Those stops are on the Pro 5.0 because the shifter was originally designed for Mustangs that -don't- have stops. The stops aren't needed for LS1s, so people generally just set them all the way out.
Old Apr 22, 2003 | 10:22 AM
  #17
Beefcake61's Avatar
I thank all of you for the information you have provided. I think I'm going to go ahead and get the ripper though. So come payday, I shall be ordering it. Anything I need to know about when doing the swap??
Rob
Old Apr 22, 2003 | 01:42 PM
  #18
LurkerLS1's Avatar
Installing a new shifter is pretty easy to do. For complete instructions, go here:
http://www.installuniversity.com
Click on "Install Documents", and then scroll down to the "Transmission" listing. You'll find a step-by-step procedure there.
Old Apr 22, 2003 | 06:39 PM
  #19
kinyu's Avatar
Rob
Just remember to use the thread locker. You will be upset with yourself down the road when you have to tear everything apart to tighten bolts again if you dont.
Quickss96
Jan 29, 2016 05:56 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
