Posi Rear end question
Old Aug 1, 2003 | 01:30 PM
drasgear's Avatar
I have a 2000 Z. The last couple months it has begun screeching the tires around tight corners. Has anyone else ran into this? Normally I wouldn't be that concerned being it is a posi rear, but it goes off of warranty in a few weeks, and I just want to be safe. Thanks
Old Aug 1, 2003 | 01:39 PM
KungFu's Avatar
If it's under warranty, take it in. I'm getting rearend warranty work done as we speak. I only have 1K left on my warranty.
Old Aug 1, 2003 | 02:07 PM
2002Z28SSConv's Avatar
Re: Posi Rear end question
More info please:
At low speeds?
Screeching like the inside rear tire is trying to slip on the pavement?
The front doesn't want to turn?
If it feels like the car always wants to go straight and seems to make the tires slip and hop while turning your posi is continuously locking both axles and needs to be checked out. My Silverado has done this a few times. My dad's too. My SS has never done it. But that's how I would describe it.
Did I assume correctly?
Old Aug 2, 2003 | 12:06 PM
drasgear's Avatar
Re: Re: Posi Rear end question
Originally posted by 2002Z28SSConv
More info please:
At low speeds?
Yep, that's exactly it. The posi doesn't let go all the way and anytime you make a uturn, turn in a parking lot, etc. the tires squeal. It's going in Wednesday as factory warranty is done the 16th. This is the 6th time I have had to have this car serviced since I bought it and I baby the thing! It's gotten to the point where I am seriously comtemplating selling it. What did they do to the silverado to correct it?
Old Aug 2, 2003 | 12:29 PM
I backed out of the parking spot. Turned onto the highway and nailed the gas. The back end fishtailed a little and I never noticed it again.
My dad and I both noticed it after we got on it hard and figure the posi function just didn't release easily. But after beating on it both freed up.
Sorry. Maybe you baby it TOO much.
Old Aug 2, 2003 | 04:15 PM
2000TA's Avatar
Well I had to have Rear end work on my TA and that told me it was a common prob bot at first they tried to tell me it was normal mine was not as bad as your it was only clicking in low speed turns. well hope that helps
oldschool
Feb 9, 2016 09:21 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
