Oversized Tranny Pan
Old May 21, 2003 | 10:03 PM
petegz28's Avatar
Anyone using one?
Old May 21, 2003 | 11:38 PM
5H9D0W's Avatar
I just put a B&M deep trans pan in mine.It holds an extra 3 quarts,and it has a drain plug.Remember,90% of all trans failures are due to excessive heat.It sits lower than my 3in exhaust.
Old May 22, 2003 | 07:57 AM
petegz28's Avatar
Is it so low you have to be extra careful on the slightest bumps?
Old May 22, 2003 | 11:35 AM
5H9D0W's Avatar
Unless you plan on doin some off-road racing,if not,I wouldn't worry about it.
Old May 22, 2003 | 11:40 AM
SteveC's Avatar
From: Poway CA, where GOD and the sun always shines
Smile
I too just had a B&M 3Qt. deeper transmission pan, coupled with a B&M 24K cooler installed on my 2001 Z28 (stock height). In my case the pan DOES NOT hang down as far as my 3" Y pipe, or as low as my SLP SFC, however clearance maybe an issue with this pan if your car is lowered.
I totally agree with 5H9D0W, heat is the big killer of transmissions. After the above install, my transmission was filled with 8 Qts. of fluid not having a converter drain.
I have no problems with bottoming out going over dips or speed bumps.
Hope this helps you out in some way.
SteveC
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
wbspoon
Sep 19, 2015 08:12 AM
