Which one of these inside cluster panels is correct? Details inside
I don't know why I noticed this, but I did.
I was looking at someones stereo they had for sale (in this post) and I came across this pic:
Shot of the Radio and surrounding area.
Look where the "CAMARO" lettering is - inbetween the traction control switch, and the fog lamps.
I then noticed mine isn't like that. Mine has the traction control delete button, the fog lamps and then the "CAMARO" dash lettering.
Heres a poor pic of my dash:
http://wicked.cz28.com/98camaro/98camaro7.jpg
(You may have to copy and paste)
You can hardly see mine, but it gives you an idea of what I'm taking about.
This is in his sig:
99 Z28 M6
I have a '98 Z....is there a difference between the dashes? Or is there a different dash set up if you have Traction control?
Milo
This is in his sig:
99 Z28 M6
Milo
The little "CAMARO" tag thingy is just clipped in there.The panel has 4 holes that 4 switches can go into.If you pop the panel around the radio off you can see what I'm talking about.If you want yours like that too then all you have to do is move one switch to the far hole and put the "CAMARO" tag in the 2 middle hoels.Good luck.
Kevin
1998 Black Z28 A4
-------1/8-------
8.584 @ 83.64 MPH
Taylor 10.4mm wires,!EGR,!FRA,SLP Lid,MAF Ends,Manual Fan Switch,and Dynomax Cat-back
BMR STB and Sub-frame Connectors
Pics
[This message has been edited by nikkev (edited July 11, 2002).]
Kevin
1998 Black Z28 A4
-------1/8-------
8.584 @ 83.64 MPH
Pics
