oil pressure dropping to zero and stalling
My brother in law has a 2000 camaro that has randomly stalled 3 times over the last couple months. In all cases, the check oil pressure light has come on. When he checks the gauge the pressure drops to zero right before the car stalls. This has happened ideling at a stop light as well as while on the freeway. Any one have any ideas why this would happen ?
My oil pressure drops like a rock under heavy acceleration in first gear. I always assumed that was due to starvation. Whoever thought it was a good idea to put the pickup in the front of the pan should be smacked.
Hopefully, your friend hasn't spun a bearing or something.
I'm surprised some aftermarket company hasn't already come up with something to fix that problem. Is this common?
Maybe your pickup tube o-ring is bad and you're sucking air thru that.
It only does it in first though. Wouldn't a bad o-ring do it in every gear?
Jul 4, 2005 05:00 PM
