Octane
Old Feb 10, 2003 | 07:29 PM
cdmelcher's Avatar
Octane
I hate to sound cheap but lately I have to wonder if I can justify using ONLY 92 ocatne. Here in the midwest 92 ocatne is the highest rating of gas around and that was ALL I used. Unfortunatly tonight kind of made me wonder what are the REAL facts for our LS1's where fuel is concerned.
I just paid :
$ 1.89 a gallon for 92 octane
If I alternate with 91 octane to save like 15 cents will there be any decrease in performance?
Old Feb 10, 2003 | 07:34 PM
stik6shift98's Avatar
im gussing it should be fine
i only use 93.....sometimes like once a year 92 at ghetto pumps
Old Feb 10, 2003 | 07:37 PM
98whiteZ28's Avatar
well if ya want you could always add a can of octane booster to the tank before fill? i use to put 93 in and an octane booster she seemed to run a bit smoother.... tes it out ya might like it?
Old Feb 10, 2003 | 07:53 PM
jd13's Avatar
You should be able to run 91 just fine. If it saves you $0.15 like you say, then it's definatly worth a try.
Old Feb 10, 2003 | 08:21 PM
Jack&Dee's Avatar
I am running 89 at the moment. 30 cents a gallon cheaper then 93... idle is rougher but not by much. MPG is a little worse but I am not hot rodding all over town on it too... A lower grade gas may give poorer peformance but it's not going to blow up your car. Unless your planning on hitting the strip or have to show your kahonas to everyone that revs you, why not go lower.
Old Feb 10, 2003 | 08:26 PM
JDHarris's Avatar
I wish to god that I could run 92 or 93 octane in my car. I currently run 91 (the highest commonly available in Southern California) and I get bad pinging at high rpm in warm weather (75-80+). I also get a significant power loss as a result of the pinging when it sets the timing back. I have heard good things about the torqo (sp?) brand octane booster, but I haven't tried it yet.
Old Feb 10, 2003 | 08:34 PM
ya i get bad pinging when on 87....i put it in on accident once
Old Feb 10, 2003 | 09:14 PM
Capn Pete's Avatar
Exclamation
Man, there is a BIG misconception about grades of gas!!! I've been running 87 octane in my car since pretty much day one. YES, I have run tanks of 91 octane (especially before I went to the track) but since the BOOK STATES:
  • 87 octane is acceptible
  • 91 octane is recommended
I've been running 87. For me, I use my car as a daily driver, and I've already racked up over 13,000 miles in just over 6 months. For the odd time where the engine "pings" under quick light load applications, the computer adjusts the timing, and the car still pulls well enough for street purposes. The only reason for using higher octane gas, is for the anti-knock properties (which only occurs under sudden load.........it's not always pinging while just driving along). I don't understand the need to use higher octane than 91 though...........it's totally wasted $$$ and fuel, and you're car would actually run worse through an emissions test. Since we have to have cars e-tested here in Ontario, that's a consideration, and it's been proven that a car will run cleaner on lower octane gas than higher octane (because there is less un-burned fuel).
I realize some of you may think it's a sacrilege to run 87 octane regularily, but my dad is a mechanic, and has assured me that my engine won't "blow up" because I'm using it. And again, the OWNER'S MANUAL says it's OK, so while the car is under WARRANTY, I have no problem doing what the book says (although I'm not stupid enough to run 87 at the track, because I realize I'll be running with slightly retarded timing, and hence a little less performance ).
Old Feb 10, 2003 | 09:22 PM
stik6shift00's Avatar
i live in the midwest..i see 93 all the time....i think BP has it...
Old Feb 10, 2003 | 09:27 PM
cdmelcher's Avatar
not in Iowa
I've driven thru IL and noticed as soon as I cross into IL yea, 93, NOT in Iowa anywhere. That is where I get 92 Octane at the Amaco BP. Even 92 Oct is not available at other stations,,,
Old Feb 10, 2003 | 10:44 PM
92 is ok i guees but nothin lower.....no 87 crap
Old Feb 11, 2003 | 01:14 AM
camaro98_speed's Avatar
I use 91, thats the highest here in California, and I got some pinging. Then I installed the 160 thermostat and the problem had gone away, for the most part. If I had 92 I would use it, but im stuck with 91. There is one 76 station with 100 octane. When I mixed some of that in, my problems went away. But it is $4.29 per gallon. 91 is $2.01 a gallon.
jp
Old Feb 11, 2003 | 07:13 AM
bsmith's Avatar
I use the best that I can get, usually 91. I have absolutely no problems in normal driving conditions. I never hear any pinging either.
Old Feb 11, 2003 | 09:20 AM
4 .29
Old Feb 11, 2003 | 11:11 AM
Topless01WS6's Avatar
How about 94 octane? Ive herd thats available at Sunco. But the most ive found was 93.
