obd2 code 430
Old May 12, 2008 | 07:47 PM
cheapthrill's Avatar
obd2 code 430
just acquired an obd2 code reader and came back with this 430 code that relates to camshaft positioner sensor ,car runs fine ,bought it used a year ago and was wondering if maybe the dealership had repaired it and didn't remove the code,
If the sensor was bad wouldn't I notice it in the performance end.seems to have great power,no missing ,knocking, etc.
Old May 13, 2008 | 09:43 AM
2001NBMZ28's Avatar
P0430 is a passenger side cat inefficiency code...
Old May 13, 2008 | 11:51 AM
ss.slp.ls1's Avatar
^+1.
The code for the cps is P0336, and the cps has no effect on performance, its there for misfire detection. Most likely you need a new cat, but bad cats are usually a symptom of another underlying problem (running rich, coolant in the engine, etc).
Old May 13, 2008 | 12:12 PM
2001NBMZ28's Avatar
Looked at a couple of your posts, since you have an 02 and less than 120K the cat is covered under warranty.
Old May 13, 2008 | 07:41 PM
obd2 code
thanks for info , does this site have a list of obd2 codes for 2002 camaros ? the reader I have came with a book of codes for what car I don't know. MAde in CHINA
Also I reset the 430 code and was wondering how long it should take for it to show up again if there is a problem??
Old May 13, 2008 | 07:52 PM
2001NBMZ28's Avatar
Best place to look up code descriptions/diagnostics for 98+ is gearchatter.com
HectorM52
Jul 30, 2017 11:46 AM
1996LT1Z28
Apr 22, 2015 07:56 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
LT1
Jul 2, 2002 08:27 PM
