o2 sensor or simulator
Old Nov 23, 2002 | 04:18 PM
hotrodgirl's Avatar
My SES light came on, so I went to Auto Zone and the computer showed codes for the bank 2 sensor. I'm getting FLP long tubes in a few weeks, and I might use the off-road pipes occasionally. My question is, should I replace the sensors or buy simulators?
Thanks in advance, I'll appreciate any input!
Old Nov 23, 2002 | 04:25 PM
psychocabbage's Avatar
If you are getting the FLPs and getting them installed soon, may as well just get the sims..
Old Nov 24, 2002 | 04:03 AM
GatotsuZeroshiki's Avatar
the simms are for the rear O2 sensors, aren't they?
Old Nov 24, 2002 | 10:16 AM
Blkknight's Avatar
You can run them front and rear.
You may have to run rear sims. But the fronts sensors you can leave on if you don't want to spend the extra money.
Adam J
Old Nov 24, 2002 | 10:39 AM
supersp0rt's Avatar
no need to change the front sensors, just run simms in the rear.
Old Nov 24, 2002 | 10:42 AM
V6toZ28's Avatar
Adam J
Uhhh ... that's a big negative there, Blkknight. O2 sims are strictly a replacement for the rear O2s.
Old Nov 24, 2002 | 10:44 AM
Kwiksilverz28's Avatar
No. You can only use the sims in the rear. The front ones are the ones responsible for mixture control. The rear ones are to ensure the catalysts are working correctly. The sims fool the computer into thinking the cats are good, even if they are missing.
generaldave
Sep 25, 2015 06:48 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
