Need some help with coolant light
Old Aug 30, 2004 | 08:19 PM
1stls1's Avatar
I know this should be simple, but my light came on tonight. I added water to the resivore, then started it. the light was still on. B/C I just got home, I let the motor cool off and checked the radi. I added some to this and the light is still on!! All the while the temp is fine. I even DROVE it to get it hot, but nothing. WTF!!
Old Aug 30, 2004 | 08:28 PM
angel71rs's Avatar
Re: Need some help with coolant light
The sensors are junk, replacements apparantly not much better. I just disconnected the connector to mine so the light would go off.
Old Aug 30, 2004 | 08:52 PM
95GRNZ's Avatar
Wink Re: Need some help with coolant light
Very common problem w/4th Gens. You have three options: unplug it, try cleaning it or replace it.
TS
Old Aug 30, 2004 | 09:24 PM
1stls1's Avatar
I'll try and let you know.
Old Aug 30, 2004 | 09:42 PM
1stls1's Avatar
Is the sensor the square metal thing just below the cap next to the battery side. Motor too hoy right now, I'll go for it in the morning, thanks for any input.
Old Aug 30, 2004 | 09:50 PM
Need4Camaro's Avatar
It may not be the sensor, have you tried bleeding air out the system? that happened several times with my dad's Z28... bleed the air out and it goes away.
Old Aug 31, 2004 | 05:11 AM
AL SS590 M6's Avatar
Moderator
There are no air bleeding problems with the LS1 setup. The sensors are so bad that GM gave up on them an deleted them in 2000.
Old Sep 1, 2004 | 05:04 PM
I see, in 2000 + how do you know if you're low on coolant?
Old Sep 1, 2004 | 06:03 PM
BirchMan98z's Avatar
Open the cap and look.
Old Sep 1, 2004 | 09:45 PM
red96taA4's Avatar
if you do pull off the sensor, you should be careful, cause once you pull if off the radiator...coolant is coming with it...
Old Sep 2, 2004 | 04:27 AM
Moderator
The same way people have for the last 100 years. Check it manually every once in a while.
Old Sep 2, 2004 | 10:26 PM
1stls1's Avatar
Sorry about the delay. I guess it is the sensor, but does this sound right. When you start it up cold, no light. But when you drive it and get it real hot(not just ideling), it comes on. Start it in the morning, It is off. The delay was b/c of that GD hurricane, needed to get ready for it, this one is coming right at me this time!
Old Sep 3, 2004 | 05:40 AM
red96taA4's Avatar
good luck with the hurricane
Old Sep 3, 2004 | 11:16 AM
1stls1's Avatar
Thanks, the coolant light is the last thing I'm worried about w/ my car. It will be out side during this little storm!
Old Sep 3, 2004 | 11:47 AM
NEWBIE T/A's Avatar
Exclamation Sounds opposite to me !
On my '99 , the coolant light would come on when it was cold - after the temp gauge reached the 1/4 mark I could turn the car off, restart it, and it would go off.
I say would cause I got fed up, and unplugged the wires !
It was a known problem on the '99's - not sure if the '98's had 'em, and they dropped this in '00.
I went through 3 before unplugging it.
That's weird that yours is working 'backwards" - ?
Britt
P.S. Good luck with the hurricane !
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
warmeck
Apr 16, 2015 05:50 PM
captcorvette
Mar 7, 2015 12:37 PM
MattFick
Feb 15, 2015 10:16 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
