Need a smooth idling cam
Old Mar 28, 2008 | 08:05 AM
JDMZ28's Avatar
I want a cam similar to a stock 02+up Z06 but better. Does anyone know of a good aftermarket cam with a stock idle? Sound clips would be appreciated if you have them.
Old Mar 28, 2008 | 10:25 AM
jmmullin's Avatar
Some people like the 220 cams and I've heard the 224R can be pretty tame... but I am waitin for a 232/234 cam to come in.
Everyone says "Its all in the tune"; if you get someone to tune the car after the swap, it will run and idle great! Don't skimp out on the tune ($4-500 ish, right guys?) Also, I believe the Lobe Separation Angle (LSA) needs to be higher for a *better* idle, depending on what your definition of better is. 114 LSA or higher for your needs, lower for a choppy grumble.
Old Mar 29, 2008 | 07:38 AM
JDMZ28's Avatar
I will do the tuning, I have a wideband and HP tuner as it says in my sig. I want a cam that has a idle EXACTLY like stock, they did it with the z06 so I would imagine someone in the aftermarket makes one. Maybe I should just get a custom grind?
Old Mar 29, 2008 | 08:32 AM
OLD 69's Avatar
I went to big in cam choice in my car although its not an LS1.Going to big a Cam just plain sucks for any typical street car!!!
Old Mar 30, 2008 | 05:26 AM
AL SS590 M6's Avatar
Moderator
Thunder racing Cheat'r or MTI Stealth maybe.
Old Mar 30, 2008 | 11:15 AM
Bayer-Z28's Avatar
^ Just what I was thinking... Just enough lift and duration to feel it...
http://www.thunderracing.com/catalog...&vid=3&pcid=51
Thunder Racing Custom Camshaft
"CheaTR" - 214/230 .601/.575 117 LSA.
Off Idle-6800 RPM Power Band. Broad power range. Works well with stock exhaust manifolds and catalytic converters. Stock like idle. Minor tuning required on automatic transmission cars. Responds very well to nitrous. Due to the fast ramp rate of this camshaft, the use of 1.8 rockers is not recommended. Double valve springs and titanium retainers required for this cam.
-OR- For something a little different....
"TR 220-114" - 220/220 .551/.551 114 LSA
1500-6500 RPM Power Band. Computer Tuning Required with automatic transmission cars. A very well balanced camshaft that makes excellent power across the entire RPM range. Due to the fast ramp rate of this camshaft, the use of 1.8 rockers is not recommended.
Old Mar 30, 2008 | 11:29 AM
Greed4Speed's Avatar
Check out the Lingenfelter GT2-3. It idles totally stock.
The other stealthy grinds do have a slightly irratic sound to them.
Old Mar 30, 2008 | 06:21 PM
JDMZ28's Avatar
I've heard good things about the GT2-3. I have heard that it does have a slight loop at idle and I've also heard that it doesn't so I'm not sure about it. Then again I've also heard exhaust clips with the zo6 cam some have loop others don't, I guess it IS all in the tune.
Old Mar 30, 2008 | 07:51 PM
Kraest's Avatar
Retired
It's all in the tune. Check out my car. F-14 Highlift .. 232/234 .640 lift 112 LSA.
Hardly any lope at all...
http://s205.photobucket.com/albums/b...t=MVI_2345.flv
http://s205.photobucket.com/albums/b...t=MVI_2349.flv
I kid. I kid.
Old Mar 30, 2008 | 09:06 PM
A friend of mine had the GT2-3 and GTP ported heads. It idled like stock and put down 400 whp.
A tune does make a huge difference though. I met a guy who has a G5X3 cam that idled like my 226 grind.
Old Mar 31, 2008 | 02:25 AM
JDMZ28's Avatar
So assuming the tune is ironed out a "stock" smooth idle is achievable. I guess I'll just call lingenfelter to confirm. What can I do to the tune to help the idling?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
BPS
9
Mar 5, 2015 10:51 PM
Fatdog2
Feb 13, 2015 08:19 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
