Need help - foglight bulb replacement
Old Feb 12, 2003 | 11:32 PM
BlazeOne's Avatar
I've got a 2000 Z28, and the passenger side fog light went out. This is the first time so I need some help. I need to know what the replacement part number is and where I can buy it. Also how to I get to it? Thanks.
Old Feb 12, 2003 | 11:37 PM
stik6shift98's Avatar
undo the bottom plastic thingy with the lil vent like things....im bein really specific i kno......
but you get to it from the bottom.... hard to explain
i hope that helps at least a bit
Old Feb 13, 2003 | 08:14 AM
PAGregSS's Avatar
The bulb number is 894.
To gain access from underneath, there is a plastic flap directly in front of the front wheel. It's held closed by two 10mm bolts that are located towards the outer edge of the car. Once you remove the two bolts the flap will swing open and you'll get a clear view of the foglight bulb.
Old Feb 14, 2003 | 08:46 PM
BlazeOne's Avatar
Thanks for the info guys!!!!
Old Feb 17, 2003 | 11:47 PM
BlazeOne's Avatar
Just changed the bulb and it was a snap. Replacement took about 10 minutes. I purchased the bulb no. 894 at Pep Boys for $9.98, removed the 2 bolts, and she was in. Simple enough thanks to the members at CamaroZ28.com!!!!
Old Feb 18, 2003 | 01:33 AM
SpecForceZ28's Avatar
Glad it worked well for ya, I just replaced my whole stock foglight housing, it was a pain in my butt.
PROJECT X
Apr 17, 2015 12:13 AM
silvermansteve
Mar 4, 2015 05:02 PM
squarehead
Jan 15, 2015 07:02 PM
