need help ASAP...car wont start!!
Old Mar 10, 2007 | 05:50 AM
krazykorean35's Avatar
ive got a 98 ls1 m6. i installed a shift light, and had it all hooked up( spliced into the white35 wire in the pcm, power from the asr button and grounded, hooked up the battery...car wouldnt start!...the engine turns over, but just wont kick. friend of my said it was the VATS (vehicle anit theft system) because i had disconnected the battery and that id need to reset it...ive never heard of this. any advice/help??!
Old Mar 10, 2007 | 11:41 AM
Bayer-Z28's Avatar
sounds like it interrupted the cam signal to the PCM. Re check the connection to the light, make sure you didn't inadvertently kill the signal/cut the wire.
I take it you used one of the blue splice connectors... ?
Old Mar 10, 2007 | 01:18 PM
i used pink ones...
Old Mar 10, 2007 | 02:47 PM
come on!! anyone got any ideas!?!?
Old Mar 10, 2007 | 07:45 PM
98mustang_vert's Avatar
It could be a bad ignition relay. My car started doing the same, the engine would crank but not start. $11 from Kragen. Relays are located in the fuse box under the hood. Hope that helps.
Old Mar 10, 2007 | 07:50 PM
iamsickofitall's Avatar
was that pin 35 (white wire) on the blue PCM connector cause that's the one it should be. if it was on the other connector, that may be causing your problem, however i don't know what is on that pin.
otherwise i would check all ignition relays and fuses and make sure that the fuel pump is priming before you go to start the car. if it's not, check those fuses too.
silvermansteve
Mar 4, 2015 05:02 PM
eazyZ
Mar 1, 2015 07:12 AM
Alex Barnes
Jan 24, 2015 10:21 PM
Amshnock
14
Jan 18, 2015 11:47 AM
Black Sunshine/ 00SS
Aug 24, 2002 03:41 PM
