need a fast easy answer
Sure, I can't see why not?
AFAIK, the LS1 is the same from '97 C5's through '02 F-bodies and the current C5's. There were a couple years where the cam specs were a little different, but the lifters should still be the same..........they have nothing to do with the cam profile.
Unless someone can say definitely that they WON'T work, then I think you're OK
AFAIK, the LS1 is the same from '97 C5's through '02 F-bodies and the current C5's. There were a couple years where the cam specs were a little different, but the lifters should still be the same..........they have nothing to do with the cam profile.Unless someone can say definitely that they WON'T work, then I think you're OK
May 15, 2015 10:43 AM
