alot of lights came on dash
Old 12-21-2017, 10:48 AM
AlmostJimmyPage's Avatar
2001 Camaro z/28 146K Miles
A few days ago my car volt meter would dip into 7 or lower and the CHECK GAUGES light would come on. I would rev the moter and it would go back to a safe reading and light would go off.
Driving to work today I had the Volt meter go to 18, AIR BAG, ABS INOP, and BRAKE Lights come on.
I turned around and went home. I replaced the alternator less than a year ago, and had a similar issue with the volts drop. I took the alternator to be tested and it tested ok.
Do you all think this is just a bad alternator that has an issue when under a load?
Thanks.
AlmostJimmyPage is offline
Old 12-21-2017, 12:01 PM
DrewHMS97SS's Avatar
Re: alot of lights came on dash
I'd think if the alternator tested good, that the battery is more likely the issue. Did you also have the battery tested?
DrewHMS97SS is offline
Old 12-21-2017, 12:25 PM
terminal_crazy's Avatar
I’d suspect a loose ground or crap\dirty battery connection.
HTH
Mitch
terminal_crazy is offline
Old 12-23-2017, 11:30 AM
rwb
rwb's Avatar
Check all your grounds, the ones attached to the head, also ground the alternator with an extra ground.
rwb is offline
1fast Firechicken
04-14-2005 03:07 PM
Black6SpdTA
05-17-2004 08:24 PM
rlax31
11-06-2003 11:55 AM
phoenix916
3rd Gen / L98 Engine Tech
08-10-2003 11:16 PM
Quick Reply: alot of lights came on dash
