alot of lights came on dash
Old Dec 21, 2017 | 10:48 AM
AlmostJimmyPage's Avatar
2001 Camaro z/28 146K Miles
A few days ago my car volt meter would dip into 7 or lower and the CHECK GAUGES light would come on. I would rev the moter and it would go back to a safe reading and light would go off.
Driving to work today I had the Volt meter go to 18, AIR BAG, ABS INOP, and BRAKE Lights come on.
I turned around and went home. I replaced the alternator less than a year ago, and had a similar issue with the volts drop. I took the alternator to be tested and it tested ok.
Do you all think this is just a bad alternator that has an issue when under a load?
Thanks.
Old Dec 21, 2017 | 12:01 PM
DrewHMS97SS's Avatar
Re: alot of lights came on dash
I'd think if the alternator tested good, that the battery is more likely the issue. Did you also have the battery tested?
Old Dec 21, 2017 | 12:25 PM
terminal_crazy's Avatar
I’d suspect a loose ground or crap\dirty battery connection.
HTH
Mitch
Old Dec 23, 2017 | 11:30 AM
rwb's Avatar
rwb
Check all your grounds, the ones attached to the head, also ground the alternator with an extra ground.
1fast Firechicken
Apr 14, 2005 03:07 PM
Black6SpdTA
May 17, 2004 08:24 PM
rlax31
Nov 6, 2003 11:55 AM
phoenix916
3rd Gen / L98 Engine Tech
Aug 10, 2003 11:16 PM
