magnaflow vs corsa?
I have a 99 z28 which still has the stock exhaust, I have narrowed it down to magnaflow and corsa but I am stuck in between. To my knowledge these 2 are the best all around in performance gains looks and sounds. Anybody have any opinions?
i have the magnaflow and i thoroughly enjoy it. just waiting to get some lt's to make it louder. it is fairly quiet compared to some others at idle, but from what i have heard from spectators is that it sounds nice at WOT.
Hey Guys,
I'm looking into getting this muffler for my car.
http://www.exhaustproslinc.com/magcammuf.html
Will it give me the same type of sound and performance gains you're all talking about and when I start my car, will you be able to tell I've got a muffler? Is the sound noticeable at idle speeds?
I was having much the same debate with myself about 2 years ago, but my choices were Magnaflow, Corsa, and GMMG. I ended up going with the Magnaflow. That being said, all three sound and look great imo. I think that you'll be happy with either one. Good luck!
-Mike
-Mike
Originally posted by CODY BEHNKE
Like I always say Magnaflow isn't really one of the best flowing due to there baffle right inside the inlet. SLP blows the Magnaflow system away.
-Mike
It's pretty much a common sense thing. Sure they flow good but only when compared to stock or a Flowmaster. The Magnaflow mufflers used for flow tests are the single outlet strait through models not crossflow.
That is b.s. Go on LS1.com, there have been dyno tests done with the Magnaflow catback & a cutout. With the cutout open several cars only dyno'd 2-4rwhp more. Sounds like a restrictive exhaust there!
The Maganflow is generally considered on of the best flowing exhausts period. Forget slp, that company is a joke.
. Magnaflow mufflers ARE a straight through design... Heck, the company motto is "Wide Open Performance". As SunsetWS6 said, check some other sites. Tests have been done comparing flow numbers from various aftermarket mufflers/systems and Magnaflow certainly doesn't come out near the bottom.-Mike
You can do some more in depth searching but I found a few threads about the Magnaflow catback. In flow tests the Magnaflow catback was the highest flowing system with a muffler at 1100cfm. The only exhaust to beat it out was the slp loudmouth, but it doesn't have a muffler so it should be.
http://www.ls1.com/forums/showthread...ight=magnaflow
In one dyno test a member gained 1rwhp with a 3" cutout over a Magnaflow catback which as you know dyno's are +/- 4-5rwhp so looks like the Magnaflow catback is damn good!
SLP a joke?
Maybe they changed there design in the last year but they did use to have a baffle right inside the inlet.
Every test is different but all SLP, Ultraflow style mufflers flow about the same.
The only oter reason I dislike the Magna flow system is the tips some of them use
SLP 2 OTL has always dynoed high. I agree about the ugly tips on the Magnaflow. If you want it at cost, go to LS-1.com and look in New Products and Sales from our Great Sponsors!. Then look in Magnaflow Products. What do you guys think about B&B Tri-Flow?
I think I've decided to go with magnaflow. Thanks guys!
