Maft
Maft
should I buy one for 60 bucks? Is it worth it? How much of a hp gain can you feel?
When I go to adjust the AF/R, can I do it on my own or do I need ATAP or Edit? Or should I dyno it? Id rather not dyno it unless I have to. Is there a setting that will help you out if you are running too rich/lean to make a little difference without knowing the exact numbers?
