Ls6 Pcv??
Old Nov 9, 2004 | 08:27 AM
Meccadeth's Avatar
Ls6 Pcv??
How many of you have converterd your <00's LS1 PCV to a '01+ LS6 PCV? Any instructions/pointers? Was it a cure all?
Old Nov 11, 2004 | 06:45 PM
BandDirector Blk98ZM6's Avatar
Re: Ls6 Pcv??
...I just bought a crate LS6 longblock to get the LS6 PCV Set-up
Anyway, try this link for the instructions you're looking for:
http://www.ls1howto.com/index.php?ar...49ab3fb0501551
Old Nov 11, 2004 | 10:54 PM
pkincy's Avatar
Re: Ls6 Pcv??
No, I don't believe that it is a cure-all. But it sure is better.
I did just burn a piston and I suspect that the detonation was caused by oil in the intake charge. But it probably would have happened sooner with the old pcv system.
The only trick is grinding the small block lifting tab of the interior of the block valley on the passenger side. I did it with the motor out of the car and on a stand. I have known people that did it in the car. Just be careful.
I also added a paper filter in the pcv loop from valley cover to the TB. Worked good for a while.
Perry
Old Nov 13, 2004 | 04:11 AM
AL SS590 M6's Avatar
Moderator
Re: Ls6 Pcv??
Then there are those of us who got an LS6 style block in their 00 Formula so I didn't have to grind any tab. And I'm going to run a catch can.
JJOHNROE
Parts Wanted
Oct 23, 2015 02:03 PM
drt
Sep 27, 2015 04:39 PM
speedracer1280
Sep 8, 2015 06:12 AM
surreybrad
Aug 10, 2015 09:34 AM
realistyc
Jul 28, 2015 07:32 PM
