LS6 heads on a LS1?
I was wondering if a set of LS6 heads with cam and LS6 intake manifold would bolt right onto a LS1 motor and if the PCM would need to be modified at all?
98 Red Z28 A4 bought on 4/02/02.
Flowmaster, K&N Filter, Flowtech Dump pipe.
Best 1/4: 13.554 at 102.62
should bolt right on they have the same block. i dont think that you have to do anything with the pcm it will read the differences in air flow and adjust itself.
98 Z28, Onyx Black, A4, t-tops, other than the free mods, a random tech cat back, and a whisper lid, it is stock
You might find that you need to add a little more fuel I recall Nick from ARE saying that the LS6 intake (this was in 1999) leans out the cars up top.
Our gm sponsor on LS1Tech has given me a lot of info about the GM LS6 CNC heads check out some of the relevant threads.
I last made 450rwhp with my current setup (unlocked) but am going to stage III LS6 heads and possibly a stronger cam, I hope to have the highest NA dyno #'s in Chicago, 480rwhp unlocked and 500rwhp locked.
1998 Formula | ARE 422ci iron block with Stage II heads | 40 lb Injectors | LS6 Intake | TTS headers | 3" ORP | Mufflex 4" Catback | MSD Wires | Whisper lid | SLP MAF | FLP level IV 4L60E | Yank TPE4400 | Moser 9"/4.10's | RT Torque Arm | HAL Shocks and Springs (front) | V6 Springs (rear), Alston 8 pt Rollcage | Airlift Airbag | Weld Prostars | ASCD Hood | 11.15@120.30mph 1.53 3625 raceweight LS1TECH.COM
Hotrods&Muscle
Feb 18, 2015 06:38 PM
Hotrods&Muscle
Jan 28, 2015 09:35 PM
Hotrods&Muscle
Jan 24, 2015 09:57 PM
Hotrods&Muscle
Jan 18, 2015 08:08 PM
Hotrods&Muscle
Dec 21, 2014 03:57 PM
