ls6 heads
ls6 heads
I just bought a set of ported ls6 heads, I want to have them milled to bump up the compression I need to know how much i can have milled off them with out worrying about ptv clearence I dont want to cut the pistons. I have the trex cam .609/.612 lift.
http://www.texas-speed.com/shop/item...d=602&catid=36
you have a ls1 correct? dont see anything for lt1. the above link is for the standard 3.9" bore but they have them for 4.0" also
i doubt you would need the shorter pushrods (but no promises), i didnt, even with the milled down 5.3l heads. i get piston slap at startup, but so do many others here. im ~11.1:1 im told, idk for certain
that cam will clear with STOCK valves and STOCK head gaskets with no milling.
Not sure how much you could mill before P/V contact. Thinner head gaskets and larger valves will require fly cutting the pistons.
Lloyd
Lloyd
Hotrods&Muscle
Jan 28, 2015 09:35 PM
Hotrods&Muscle
Jan 24, 2015 09:57 PM
Hotrods&Muscle
Dec 21, 2014 03:57 PM
hotrodyou1
Dec 20, 2014 10:05 PM
