ls6 heads?
Old Jan 11, 2006 | 11:11 PM
98blckz28's Avatar
ls6 heads?
Was thinking about buying ls6 heads instead of messing with gears and air intake. I found a pair of ls6 heads on ebay for 700 bucks and others were going for around 2 to 3grand. What kind of increase in power should I see from these and are they worth the cash. Would I also have to do any frame work or suspension? Thanks alot guys
-Josh
Old Jan 12, 2006 | 06:22 AM
teke184's Avatar
Re: ls6 heads?
frame work or suspension for new heads??
that's kindda like asking if you need to change shoes because you got a haircut.
on a bolt on car, you'd probably pick up 10hp with the LS6 heads (unported). not really worth the hassle. since you'll be spending $250 on gaskets and head bolts, on top of the $700 for the heads.
now if you wanted/needed them for a core to get some ported LS6 heads for a H/C setup...that's different.
there are many other mods worht doing, for less money and better gains, than just swapping heads
Old Jan 12, 2006 | 08:18 AM
Kraest's Avatar
Retired
Re: ls6 heads?
Dude, one thing at a time... Seems as though your knowledge of cars is quite limited, so let me put it simply:
The first thing you want to do to increase horsepower of your car is bolt-ons. Exhaust, Lid or CAI, Headers, etc. If your car is an automatic, the next thing I'd do would be to get a converter and some gears.
Then if you want, start thinking about more major stuff like cam, ported heads, stroker motor, etc.
Mike
Old Jan 12, 2006 | 08:12 PM
98blckz28's Avatar
Re: ls6 heads?
Yea I am just starting to learn about cars so feel free to correct me or give me any advice please hah. I just read somewhere on this board where the ls6 heads increased your HP dramatically. Guess that person was wrong. Thanks alot guys
Old Jan 12, 2006 | 09:40 PM
98blckz28's Avatar
Re: ls6 heads?
I really dont understand what you mean. Will you all please exlain.
Old Jan 12, 2006 | 10:55 PM
00cls1camaross's Avatar
Re: ls6 heads?
Teke said, a full bolt-on car with yeild a 10 rwhp gain.... which isnt that much. the dude after teke is saying that on a non bolt-on car will yeild more
i figured it woulde be the other way around considering with a bolton car you are making more power, then again i am no expert.
if you dont know what the boltons are to a saech for "basic boltons" and you should get a result and more
Dakota
Old Jan 13, 2006 | 05:25 AM
teke184's Avatar
Re: ls6 heads?
i re-read Kraest's post, he doesn't mention how much power stock LS6 heads would be worth.
he just says that there are other mods to be done to a car before you start messing with heads.
but you are right, LS6 heads on a bone stock car wouldn't yield much of anything. put them on a bolt on car and you'll see small gains, since the rest of the car is opened up for more air. but still this is only gonna be worth 10-15hp i would say.
you gotta remember that ported heads only pick up 30-50hp on cammed motors. so stock LS6 heads on stock cam wouldn't yield much.
to the original poster:
go through and read the first 10 pages of this forum, educate yourself with some of the common basic mods and what they are for. use the search function. keep a list of things you don't understand so you can search for info.
if you still are unsure of something. then ask.
just about every "i'm just getting started and i want more performance" question has been asked multiple times (sometimes in the same day ).
Old Jan 13, 2006 | 07:18 AM
Kraest's Avatar
Retired
Re: ls6 heads?
I'm with you. With the increased compression and flow, I doubt you'd see any more than 20rwhp increase, which sucks for the amount of money you have to spend to do it.
Hotrods&Muscle
Jan 28, 2015 09:35 PM
Hotrods&Muscle
Jan 24, 2015 09:57 PM
birdblack
Dec 30, 2014 06:59 PM
Hotrods&Muscle
Dec 21, 2014 03:57 PM
hotrodyou1
Dec 20, 2014 10:05 PM
