LS6 Heads ???
Old Aug 19, 2002 | 06:14 PM
Nathan1234's Avatar
Question LS6 Heads ???
I've heard that the LS1 block and the LS6 block are the same in 01 and 02. Would a set of factory LS6 heads be a straight bolt-on for my car, or would it make more sense to get a good set of CNC LS1 heads?
Also, could anyone give me some info on the differences between LS6/LS1 in 01 and 02?
Thanks.
2001 SS: 12K, M6, All SLP power options, Loaded, NO t-tops
SOLD:
Red '95 Formula (95k):
M6(3.42), Firehawk SZ50 EP's, Home-made CAI w/ K&N, LT4KM, some ACCEL coil, LPE Aluminum DS, and... muffler bypassed.
Old Aug 19, 2002 | 06:45 PM
redz_02's Avatar
Post
Get the proted heads. 01's and 02's are basicaly a LS6 minus the heads, it sounds logical b/c it is cheaper and quicker for GM just to make one different set of heads than a whole different motor. But if you get a set of ported heads get a cam to go with them, and possibly some long tube headers. You will see alot more gain with that. I have heard some good things about almost every manufacture. www.thunderracing.com and www.motorsporttech.com have some dynos with their combos.
'02 Red Z28, ebony leather, M6, T-tops, Trac. cont., hurst shifter
Borla (the expensive cut-out), Wisperlid W/K&N, FRA, Cags eliminator, Strange 4.10's, G2 Rear Girdle, Valv. Synthetic 10W-30, Redline gear oil, Fat hurst shift ****, Lead foot
Soon to be:
Alpine Screen, Orion xtr 800.4, xtrpro 1000, Kicker 12L7 in a milhouse, Focal polykev K2's, Focal utopia 6" audiom midrange.
Old Aug 19, 2002 | 07:34 PM
Freak's Avatar
Post
LS6 heads wont give you as much as a set of ported LS1 heads, but they cost less. Particularly when compared to the stage 2 heads.
They will give you better flowing ports and higher compression with stock heads. So you wouldnt need to screw with pushrod size.
I personaly would love to get a set of the GM CNC LS6 heads.....
BTW, you arent really buying heads when you get ported ones, you are exchanging, and paying for the porting and machinework as well as valves and valvespring/retainer upgrades. if you wnat to keep your heads (incase you wnat to go back to stock for some reason) you pay a core charge that is usualy around 500-600 bucks
If you get a set of LS6 heads you are usualy buying them outright. I knwo of no one that will exchange LS1 heads for LS6 heads
[This message has been edited by Freak (edited August 19, 2002).]
Old Aug 19, 2002 | 09:40 PM
texanmutt's Avatar
Post
FYI- LS-6 blocks have stronger webbing
Old Aug 19, 2002 | 10:27 PM
Freak's Avatar
Post
all the short blocks are teh same now, starting in 01, though I dont know if they started that at the begining of the year or in the middle
Old Aug 20, 2002 | 07:59 AM
01SunsetOrangeSS's Avatar
Post
They (GM) made the change over at the end of 2000. LS6 intake was added in 2001. The combination of the LS6 heads, cam and intake are usually good for at least 365RWHP = 435 SAE net hp.
01 Sunset Orange SS
T-Tops, Neutral Leather, ASR, Hurst 6spd, ASR, SS Grill.
Mods package: Lou's Short Stick, BMR- STB, SFC, LCA, Front & Rear Sway Bars, Torque Arm and APHR. Corsa Exhaust, SLP MAS, Lid, Smoothe bellows and Y-Pipe. Holley Power Shot filter,Hotchkis Springs, KVR cross drilled rotors, Bilstein shocks, T/A Girdle, NGK IX55, MSD 8mm Wires. Jet Stage II Chip, Hypertech 180 degree Thermostat, Royal Purple Synthetic package. ProFormance-MotorSports Inc. proform1@bellsouth.net
[This message has been edited by 01SunsetOrangeSS (edited August 20, 2002).]
Hotrods&Muscle
Jan 28, 2015 09:35 PM
Hotrods&Muscle
Jan 24, 2015 09:57 PM
birdblack
Dec 30, 2014 06:59 PM
Hotrods&Muscle
Dec 21, 2014 03:57 PM
hotrodyou1
Dec 20, 2014 10:05 PM
