LS6 cam questions
Old Apr 28, 2004 | 12:47 PM
bombd84's Avatar
LS6 cam questions
If i was going to put a ls6 cam in my car, is this all i would need?
ls6 cam
ls6 springs
retainers
maybe pushrods??
would yella terra 1.8 rockers go with that combo??
Old Apr 28, 2004 | 02:38 PM
SSCamaro99_3's Avatar
You will need pushrods (LS6 cam base circle is smaller)
retainers
valve seals (might as well)
I would also do:
Timing Set
Oil Pump
Thermostat (highly optional)
LS6 Intake (optional)
As for spring, LS6 spring will be fine at stock rocker ratios (1.7), but if you go to a 1.8 rocker the effective lift will be .587. At this lift a 918 spring becomes highly reccomended because you are outside the LS6 springs design parameters.
Hotrods&Muscle
Feb 18, 2015 06:38 PM
Hotrods&Muscle
Jan 28, 2015 09:35 PM
Hotrods&Muscle
Jan 24, 2015 09:57 PM
Hotrods&Muscle
Jan 18, 2015 08:08 PM
Hotrods&Muscle
Dec 21, 2014 03:57 PM
