LS6 Cam
Re: LS6 Cam
Originally Posted by Ls1smlblck
Do you know if he used the LS6 Springs and had it tuned?
i went with ls6 springs and had my car tuned.
i got this cam for its cost and streetability.itll make nowhere near the power down low like other cams but its good for what it is.
Re: LS6 Cam
He didnt have his tuned. I raced him and wasnt to impressed. The only gains that you will see are pretty much past 5500 rpms, therefore the only time it will really shine is when your doing high speed runs and are in your upper rpm ranges for an extended period of time. When we raced it was even untill we were about to shift then he would start to pull. Once we shifted it would be even again untill he reached the upper rpms. There are plenty of other cams out there that are just as streetable as the ls6 cam but will make substantially more power.
edit* we raced before my headers and true duals
Re: LS6 Cam
i too was concidering the LS6 cam because of its affordability, but then i realized that if i am gunna spend all that money on a cam swap it might as well be something thats gunna kick *** all over the place...i heard that the trex cams are good and the ls1 hotcams are good as well...but i have to pass the sniffer so we will see what the future holds
racecarz28
Mar 30, 2015 09:55 PM
Hotrods&Muscle
Dec 21, 2014 03:57 PM
hotrodyou1
Dec 20, 2014 10:05 PM
