LS2 Timing Chain Part Number?
Old Mar 3, 2006 | 08:51 PM
JoeMack's Avatar
Went to local dealer today to price the LS2 timing chain for my 02 Z28. He told me that the part number was the same for LS1. Is this true? I will be doing a H/C swap and I only have 19K miles on it. I don't want to change it if it is the same. Isn't the LS2 chain an upgrade? Anyone have the GM part number for it? Thanks
Old Mar 3, 2006 | 09:12 PM
Greed4Speed's Avatar
Re: LS2 Timing Chain Part Number?
It is thicker.
GM may be stocking only the LS2 chains now like they are for valve springs. I don't know the part #, but you can get them for under $40 from some sponsors. Just get it from whoever you're getting the cams/springs/pushrods from. IIRC TSP carries them.
Old Mar 5, 2006 | 04:46 AM
Bayer-Z28's Avatar
LS2 timing chain = 12586482
Check the sticky at the top of the LS* engine tech room...
Old Mar 5, 2006 | 10:32 AM
JoeMack's Avatar
Thanks everyone, that is the correct part number
Old Mar 5, 2006 | 11:48 AM
1984camaroz28's Avatar
buy a double roller and be done if ur gona with a decent sized cam
Old Mar 5, 2006 | 10:28 PM
Ya, spend about 3 times the cost when you can get the same chain thats in the 505hp LS7 for under $40.
Old Mar 7, 2006 | 06:54 PM
StudyTime's Avatar
This isn't a Gen I engine, some things have changed with the late model GM V8 engines.
Ben T.
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
