LS2 OE block max HP..?
Old May 2, 2013 | 03:32 PM
Diplomat's Avatar
I want to build a LS2 427 twin turbo. I've seen some LSx blocks make well over 1000hp without any issues. Assuming the engine tune is mild for street use only do you think I will be safe with a stock/OE 364Cu/In LS2 block out of a 07' Corvette?
Old May 3, 2013 | 01:18 AM
Bigbadwhitey's Avatar
Re: LS2 OE block max HP..?
Im not sure you can get a 427 out of an ls2?
That requires a 4 inch stroke and a 4.125 inch bore, and im not sure the ls2 can go much bigger than 4.070
Old May 3, 2013 | 10:58 AM
WhiteHawk's Avatar
I see the LS1's start to crack in the 800 range. I wouldn't dare go 1000 on an aluminum block, and the extra bore size on the LS2 makes it even weaker. Get an LSx block if you want to make that kind of power.
A buddy of mine built 2 turbo LS1's in a row and both times he cracked the block right in the middle. For the third build, he got a 5.3 iron block, did a partial fill, and punched it out to the LS1's 3.90 bore. He makes in the 800's and hasn't had an issue yet - same tune as before too.
-Geoff
GREEN3112
Feb 10, 2019 09:19 PM
RUENUF
Mar 13, 2016 03:37 PM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
heus
Sep 8, 2015 12:01 PM
