LS2 manifold fit LS1 maybe? ?
Old Oct 12, 2007 | 06:17 AM
Sunsetmaro's Avatar
Talking LS2 manifold fit LS1 maybe? ?
Hello. I have a 02 z-28. My car has the ls6 manifold with I think the 78mm intake port. I think the ls2 manifold has the 90mm intake port, Will the ls2 manifold fit the ls1 ?? ?
Old Oct 12, 2007 | 07:18 AM
Greed4Speed's Avatar
It will cost you HP over the LS6 intake. It was designed for a larger engine and with keeping cost down over performance. This is another case where bigger isn't better. Stick with your LS6 intake.
Old Oct 12, 2007 | 08:00 AM
Kraest's Avatar
Retired
LS6 intake > LS2 intake.
Old Oct 12, 2007 | 11:26 PM
Bayer-Z28's Avatar
^ I think the bolt pattern is different, IIRC..
I know we cannot use the LS1/6 intake on LQ9 style heads (and why would you want to?) .. again, bolt pattern.
You could, but for the cost, you could get a FAST 90/90 maybe.. also you'd need to do something w/ the throttle by wire TB.
I don't think it'd be worth it. IMO...
Old Oct 13, 2007 | 05:44 AM
AL SS590 M6's Avatar
Moderator
What makes you think that? I thought that all LSx heads are the same intake bolt pattern except for the C5R, LS7, & L92.
Buddy has LQ9 heads on his twin turbo Formula LS1 with an LS1 intake.
Old Oct 13, 2007 | 10:46 AM
Kraest's Avatar
Retired
The LS2 is an LS6 casting, minus the trick valves.
And Al's right.
There's a reason that you can only run the LS7/L76 intake manifold on the L92/LS7 stuff.
Mike
Old Oct 20, 2007 | 08:31 PM
RE AND CHERYL's Avatar
All teh LS2 applications use the drive by wire throttle with a different TB bolt pattern which can't be adapted to the F-body.
What are your mods? A ported stock TB with an LS6 intake can support a lot of airflow.
Re'
Hotrods&Muscle
Jan 28, 2015 09:35 PM
Hotrods&Muscle
Jan 24, 2015 09:57 PM
Hotrods&Muscle
Jan 18, 2015 08:08 PM
Hotrods&Muscle
Dec 21, 2014 03:57 PM
