...ls2...
Old May 23, 2007 | 10:48 PM
86ChevyCamaro's Avatar
Question ...ls2...
I'm wondering if you can put a LS2 in 88' Camaro Z28? or in a 86' Camaro with a 350 in it? thanks!
Old May 23, 2007 | 10:50 PM
or any other kind of engine that has 400 hp or better that suited for the car i listed above?
Old May 24, 2007 | 08:30 AM
supernova1972's Avatar
Yes, try a search. You can find all kinds of transplants. Check out the hybrids forum on ls1tech.com.
Old May 24, 2007 | 08:58 AM
Kraest's Avatar
Retired
Yep. Worst case, you can always throw a carb setup on it and not worry about the computer stuff.
Old May 24, 2007 | 03:15 PM
ok thanks!
Old May 30, 2007 | 10:29 PM
wha carbs?
Old May 31, 2007 | 12:55 PM
2000GTP's Avatar
Originally Posted by 86ChevyCamaro
wha carbs?
Carb setups are a pretty popular swap for the newer engines. I'm sure some of those combos will be on the LS1tech Hybird forum as well.
