LS1 Wheelie
About how much crank or wheel horsepower does it take to do a wheelie? I mean the minimum amount in order to do what you'd consider a wheelie. Also, how long can the stock suspension take this for? Is there any way to beef it up to take the abuse?
95 Silver Z28 Camaro
Not bad for 16, eh?
Not bad for 16, eh?
I don't know that you could do it on the stock suspension. You would most likely need to purchase a lot of aftermarket equipment to get the car to hook up well enough to pull a wheel.
- Steve - 1998 Pontiac Firebird Trans Am
LS1 A4, 2.73's, Kumho Ecsta Supra 712 245/50/ZR16's, Direct Flow Lid, GMAF, !FRA, Loudmouth, 3" Y-Pipe, AIT Mod, Fan Switch Mod
13.774 @ 103.33, 300rwhp & 308.6rwtq, 97+ RPO Codes, Join The CamaroZ28.Com Users Webring
<font face="Verdana, Arial" size="2">Originally posted by 96fbirdA4:
I don't know that you could do it on the stock suspension. You would most likely need to purchase a lot of aftermarket equipment to get the car to hook up well enough to pull a wheel.</font>
I lifted tires in 2000, with 375rwhp/408tq...
I lift them higher with 450rwhp/500tq.
PICS:
www.ls1tech.com/moderators/psj
1998 Formula | ARE 422ci iron block with Stage II heads | 40 lb Injectors | LS6 Intake | TTS headers | 3" ORP | Mufflex 4" Catback | MSD Wires | Whisper lid | SLP MAF | FLP level IV 4L60E | Yank TPE4400 | Moser 9"/4.10's | RT Torque Arm | HAL Shocks and Springs (front) | V6 Springs (rear), Alston 8 pt Rollcage | Airlift Airbag | Weld Prostars | ASCD Hood | 11.15@120.30mph 1.53 3625 raceweight LS1TECH.COM
PICS:
The only suspension mods I have done to my car are a set of G2 LCA relocation brackets, an airbag in the right rear spring, and a set of Hal QA1 12-way adjustable Hal struts. My best 60' time is a 1.588, and you can click on my homepage posted in my sig to see the picture.
This is with 361 RWHP. I am getting ready to upgrade with the G2 torque arm, lightweight control arms, and lightweight panhard rod. Another cam swap is in order, too.
Trevor - LGM
'02 SS: 11.63 @ 114.06 MPH, 1.588 60'; 3,515# raceweight, 1,102' D.A.
naturally-aspirated with bolt-ons, a cam, and a fat converter!
L.G. Motorsports (972) 272-7753
Check out the SS!
Trevor - LGM
Check out the SS!
<font face="Verdana, Arial" size="2">Originally posted by TireSmoke:
Can you do this with a stock rear end? Can the stock rear end handle many of these launches?</font>
- ie: transmission or driveshaft).To go out and start pulling wheelies, you'd need a lot of beefed up parts on your car, otherwise you're gonna start breaking $h!t left, right, and center. JMO.
2002 Z28 - A4, 2.73's, Blk/blk, leather, T-tops, sport appearance package - just bought on June 26, 2002! - Pics
1981 Z28 - 383, TH350 trans., 3.42 posi - sold August, 2000 - Pics
1973 Camaro - Dad's & my project in the works - to be built: 355 Chevy, 11.5:1 pop-ups, "camel hump" heads (w/2.02 valves), solid cam, 4-speed.....it should be quick! - Pics
