Ls1 stock. Replacing spark plugs
Old Aug 17, 2013 | 11:16 PM
mrmint69's Avatar
My stock lt1 spark plug change took three hours. Getting ready to do a ls1 stock for the first time. How long should it take? Any special tools or tricks for these? What are the best plugs for them? Thanks!
Old Aug 19, 2013 | 05:19 PM
transamtom's Avatar
Re: Ls1 stock. Replacing spark plugs
I used NGK Iridium plugs
If your running nitrous use a regular copper plug.
The LS1 should be a bit quicker,#8 needs to be done from the bottom.
Old Aug 20, 2013 | 01:54 PM
WhiteHawk's Avatar
I get #8 with a tiny snap-on 1/4" ratchet, a 1/4" to 3/8" adapter, and then a standardplug socket on the end. It is blind but I am pretty good at it after doing it a few dozen times. I always pull off the coilpacks too to make it easier to get my hands in there.
-Geoff
Old Aug 20, 2013 | 08:01 PM
Mr99SS's Avatar
I bought reg copper plugs getting them changed tomorrow with msd wires gates belts an changing coolant . im looking for high 12's tomorrow for a baseline
Old Aug 22, 2013 | 08:49 AM
mrmint69's Avatar
Took two hours including a compression check. Eight is crazy, but only took forty minutes. Thank goodness it was not on tight and threaded in easy. Thanks for your help!
Old Aug 31, 2013 | 02:19 PM
Mr99SS's Avatar
yeah pass side is hardest side
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
mritter1965
Feb 9, 2015 07:01 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Jazsun
Dec 29, 2014 12:14 PM
