LS1 to LS7. what upgrades can carry over?
Old Sep 14, 2006 | 09:59 PM
mgi ss's Avatar
I'm looking to replace my LS1 with the LS7 but not right now. Are there any upgrades I can do now on the LS1 which can be transferred and which are effective for the new LS7 such as cams, headers, etc?
Old Sep 15, 2006 | 12:13 AM
00cls1camaross's Avatar
Re: LS1 to LS7. what upgrades can carry over?
well the LS7 is a 427 ci motor... any cam speced at your 346 ci will be ****e if you put it in your LS7. Heads, i think your giong to need some big boy heads that flow like mad for the LS7.
not sure if any of the parts are interchangable. this might be a topic to research on LS1 tech.
Old Sep 15, 2006 | 06:37 AM
Eric@Victory Racing's Avatar
Is there any specific reason you are leaning towards the LS7? If it's purely a cubic inch thing, I would just do a Darton wet sleeved 427. I will get you the power you are after without having to modify anything. Below I have listed our 427 package, but keep in mind we can dress it up with additional parts such as F.A.S.T 90/90.
All of our VRE 427ci engines utilize a Compstar M.I.D. Wet-Sleeve block, forged internals, and coated pistons. As part of our Victory Lane series this engine features coated bearings through-out the entire short block. Whether your building a retro street machine or a modern day track warrior the Victory Lane 427 is the ultimate choice for power.
Specs:
Compstar M.I.D. Block
Compstar 6.125" LS1 Rods
Eagle 4.000" Crankshaft
Diamond Custom Pistons
Diamond Pro Select Rings
ET Perforamnce CNC Cylinder Heads
Comp Cams Hydraulic Lifters
GM Production Rocker Arms
Cometic MLS Head Gaskets
VRE Custom Spec Camshaft
VRE Ported LS6 Oil Pump
Adjustable Timing Set
Chromemoly Pushrods
Clevite Rod Bearings
Clevite Main Bearings
Clevite Camshaft Bearings
ARP Main Studs
ARP Head Studs
All Bearings Coated
Fully Machined Block w/Deck Plates
Balance Rotating Assembly
Blueprint and Assemble
$11,399.99
Jmlcolorado
Jul 4, 2015 08:31 AM
Jazsun
Dec 29, 2014 12:14 PM
