LS1 with 145k
totally depends on how it's been treated.
has it been raced alot??
just daily driven 200miles??
oil changed regularly??
nitrous??
run it till she pukes...then stroke it!!
nitrous??
When it dies. If it runs fine, no blown head gasket etc, why waste the money. Every day you drive it you save money and my lt1 has close to 170k. These cars can last if you change the oil in them lol.
It's 99 Firehawk in great shape but the miles are high. I just don't know If it has been taken care of oil change ect... How long can the LS1 last? I know there are a lot ifs but just guesstimating.
I'd pay $6000-7000 or walk away.
At 145k, it's on borrowed time, since it's in a high performance car and has been beat-on. A rebuild is in your future, even more near if you plan on modifying the motor in any way.
Just curious, how long do you think my LS1 can last given these conditions?
I just Daily Drive it between 100 and 200 miles daily
See's WOT maybe once every 3 months, never does burnouts, donuts or anything of that nature...
Rarely ever see's anything over 3K RPMS (because I never need more power than that.)
Typically uses Shell V-Power Gasoline, Seafoamed at 70K, run fuel injector cleaner once every blue moon...
I've been using Mobil 1 and changing it every 3K miles until I've recently found out it can be ran way longer than that... Going to 10K mile oil change intervals...
Has 80K miles on it which is twice as much as when I purchased it October of last year,,, (Had 40K then)
probably a good estimate...
but in all reality...there is NO possible way to make an estimate like that with any real accuracy.
all it takes is one missed shift at high rpm and you could trash the whole damn thing.
My 98 LS1 Trans Am has 134,400 dynoed 332.8hp 355 tq to the wheels There are alot of LS1's taking abuse with high mileage. I just sold my 99 B4C to a speedshop. The car had 120k on it a4, Lid and slp dual dual Fast intake/TB 330 to the wheels and 460 something with a 150 shot. Check it out www.harrisspeedworks.com
It's a liquid internal engine cleaner that helps remove deposits built up over time of engines running. You use some in your gas tank to clean the fuel system, some in the oil to clean the crankcase and oil side internals, and some injested thru the vacuum system while the motor is running to clean the combustion chambers.
I've seen big write ups on the net as to how to use it and then laughed when I bought some and all of the instructions are right there on the can.
