low oil light
Re: low oil light
Originally Posted by psychocabbage
There is a system that you can install that has two mega filters.. Its like doing an oil change every 5 min. Pretty interesting setup.. All you have to do is change the two filters and top off..
Linky?
Re: low oil light
It is true a good synthetic like Mobil 1, German Syntec, Redline, etc can go 7500ish miles and still give good wear analysis results. However, I still wouldn't go nearly this far on an old school hot rod. Opening the secondaries on these makes these run a little richer than alot of EFI cars and getting a little gas and contaminants into the oil from this still warrants the 3k or less change interval IMO. My friend's 79Z28 with a fresh warmed over 355 is proof of this. He uses Mobil 1 0W40 with K@N filters and after about 2k miles, the oil is pretty dirty. He also gets on it almost on a regular basis.
Jason
Jason
Re: low oil light
Originally Posted by BirchMan98z
I change my oil every 3000ish miles and it always comes out looking pretty close to what it looked like when it went in... You drive yours every day?
read the sig
I also use a fram oil filter with the rubber grip thing so I can get it off with my hands most of the time.
Re: low oil light
Originally Posted by AronZ28
read the sig
Jan 23, 2015 01:13 PM
Jul 4, 2005 05:00 PM
