Lotta squeeking on my 02 frnt suspension?
I recently got a 02 Trans Am and as far as I can tell from car fax and a paint reader, the car has never been in an accident.
There is a anyoing squeek coming from the driver side front that basically sounds like a squeeky bed!
If I close the windows and turn up the radio it drowns out but when the tops and windows are down it is getting annoying.
Can I spray some WD-40 or something somwhere? ANyone else have this problem?
thnx.
thnx.
Re: Lotta squeeking on my 02 frnt suspension?
i'm having a similar problem, when i hit a bump on the road, my rear suspension squeeks a little, and there is some kind of noise coming from the trans (i think). i got this car about 2 months ago, and also did a carfax to see if it's been wrecked. came out clean.
you might want to have the suspension greased if the problem continues. i tried WD40ing mine, but can't get the lub between the spring and the metal part where it meets. they'd have to take it apart and put some grease on it.
From: looking at thick girls in san francisco in my camaro
i got the same prob.... i have a 02 z, and when im cruising around 30-40,and i let foot off the pedal, i can feel something rubbing feeling and sound under the driver side floor(right under my foot), and when im looking for parking (i.e.), i can hear rubbing noises...what are those sounds and are they related???
02 z, a4 flowpac, 3200 vig., 3.73. lca, magnaflo, cutout
Its funny cuz I have had 3, 94 Z's and all went over 100,000. I never noticed any squeeks from them, and this 02 has just under 50,000. It seems to be coming from the driver side.
RUENUF
Mar 13, 2016 03:37 PM
